I have a stick gu2 controlling my leds. Everything was ok but now 1 light is a different color from the rest.
Also when I turn the lights off 1 fixture stays on.
Any help?
Thanks,
Chris
Help Lights are not in sync.
- photo (1).JPG (87.56 KiB) Viewed 14594 times
Re: Help Lights are not in sync.
Hi Chris
I guess this is a problem with the light, driver or cable. When you turn of the GU2 by pressing the standby button, it sends 0 to all channels (1-128).
Ok thanks.
What would be the cause of 1 fixture being a different color then the rest?
Also do you know where I can get some nice cool effects and color file for my gu2 to run?
I have 2 rooms with this setup.
Thanks,
Chris
Thanks,
Chris
Hi Chris
It could be many reasons, but most likely a faulty driver or a bad DMX connection into the driver.
You can create effects using the ESA2 software.
