hi,
im unable to update firmware from 1.07 to 1.08
i used 4 different computers and everytime it fails xp/w7. i hit patch firmware, the box is blinking after a while tools.exe returns with the message please patch to 1.08
its impossible to use suite2 anymore until its fixed
i use a siudi 8c
regards
can't patch from 1.07 to 1.08
Re: can't patch from 1.07 to 1.08
With some interfaces, it's not possible to upgrade the firmware from 1.07 to 1.08. To do this, you must start in 'bootloader mode'.
-power off your interface
-create a shortcut on p2-p3-p4-GND ports
-power on your interface
-start tools.exe
-update the firmware
-remove the shortcut
-start tools.exe
-update the firmware again
Here is a diagram showing the ports you must connect. If you don't have the correct cables for this, a quick solution is to use a ball of foil. As long as the 2 pins on the right are not connected, your interface will successfully start in bootloader mode.
-start tools.exe
-start tools.exe
it work
i built this for enter in the bootloader mode
so i can use my sunlite BC with the actual sofware ( 2017 ) on win7 and win10
thx
thx
Thank you for the photos of this method of triggering bootloader mode on interfaces that don't have bootloader pins on the PCB.
Another simpler method is to use aluminium foil which can be found in most kitchens.
- bootloader pins2.jpg (41.13 KiB) Viewed 15023 times
