ESAPRO2 - Invert Pan&Tilt / Dimmer/Switch
ESAPRO2
Can not invert Pan & Tilt like ESA2
Can not treat a Dimmer as a Switch channel
Can not change between fading and Snap channels - so if using a Moving Light with a Colour Wheel - it will scroll thought the colour wheel as is ALWAYS set to fading
If using a Dimmer to act as a Switch
ESAPRO2 Patch.jpg (106.84 KiB) Viewed 9173 times
Re: ESAPRO2 - Invert Pan&Tilt / Dimmer/Switch
Indeed, invert/swap of PT channels have not been implemented.
But you should be able to control the transition type between your keypoints by right-clicking on the transition line between your points and selecting the "cut" transition if you don't wish for a linear transition.
This way your value changes will be direct, and won't fade through the colors of your wheel.
Thanks for the work around.
Beta Issue?
if i change the mover colour in the selected timeline, the 2D Visualiser changes the colour, yet the timeline indicator square remains a white box.
I'm offline, just noticed that trying to look @ a full spectrum of 512 and trying to grasp what changing and not knowing the channels, to know what the DMX output is doing...quite a challenge.. Would be good if there was some kind of colour indication that channels are static or changing.
Noted. Thanks for the feedback.
