Hello, is there an option in the program to display everything a little larger. Unfortunately, I can hardly select anything on my Surface 4 because the icons are too small. This also happens when I reduce the resolution on the Surface. In ESA Pro 2 there is an option to change the resolution.
Thank You
Peik
ESA 2 - Screen Size on Surface 4
Re: ESA 2 - Screen Size on Surface 4
You should be able to select a bigger aspect ratio from the main menu.
