Doesn't work on Iphone 16.1
Arcolis Remote is temperamental, Overriding Speed sometimes caused a crash
ESAPRO2 - Remote Pro DE3
- Junior Forumor
Re: ESAPRO2 - Remote Pro DE3
Hello Rob,
I've had a look into this and can't replicate the issue.
Could you send me the showfile you're using on the DE3 that's crashing? Maybe it's something in particular that's causing this issue.
Cheers,
Harrison
Cheers,
Harrison
Kind regards,
Harrison Goodair
Technical Support
Harrison Goodair
Technical Support
Harrison,
The files are on my cloud - nothing too complicated as its too unreliable.
My other client who uses this feature with a Stick 5A works fine on Andriod however i have no devices, only IOS.
Regardless, even if i have any Stick Device (DE3/LR512!/CW4) - Remote connects fine. Remote pro will not connect! Refreshing device list fails.
- Junior Forumor
Hey Rob,
I've raised this with a dev and I can confirm that a fix should be released in the upcoming Arcolis Remote Pro update. I don't have an exact date to give but I should imagine this will be released in the next week or so.
Kind regards,
Harrison Goodair
Technical Support
Harrison Goodair
Technical Support
