If you patch a Single Mono Fixture or single Custom WW or single CW Fixture..
Effects will be ignored
If you patch a Red fixture for instance, Effects are not ignored.
Doesn't seem right that a Single / Mono is treated in such a low priority
ESAPRO2 - Single/Mono Chases
- Single.Mono.jpg (424.72 KiB) Viewed 7826 times
Re: ESAPRO2 - Single/Mono Chases
Color effects generate values containing specific color components.
If your color effect doesn't contain any values for the WW or CW components, your fixtures won't be affected.
In order to fix this, you can double-click or right-click->properties on your color effect and edit your colors to add values for CW and WW components.
Hope this helps.
Hope this helps.
Sorry,
The point i'm trying to make is the following, 2 ways of completing the same task, one more complicated than the other.
Patch a Single/Mono - Can't add prebuilt effects only via Timeline keypoints, add phase.
Patch a Custom single Red - can add All prebuilt effects and adjust the rainbow etc to red channel only.
