ESAPRO2 - Invert Pan&Tilt / Dimmer/Switch
Posted: Fri Oct 08, 2021 9:58 pm
by EVOLVEINSTALL
ESAPRO2
Can not invert Pan & Tilt like ESA2
Can not treat a Dimmer as a Switch channel
Can not change between fading and Snap channels - so if using a Moving Light with a Colour Wheel - it will scroll thought the colour wheel as is ALWAYS set to fading
If using a Dimmer to act as a Switch
Re: ESAPRO2 - Invert Pan&Tilt / Dimmer/Switch
Posted: Tue Oct 19, 2021 11:24 am
by TomHat
Indeed, invert/swap of PT channels have not been implemented.
But you should be able to control the transition type between your keypoints by right-clicking on the transition line between your points and selecting the "cut" transition if you don't wish for a linear transition.
This way your value changes will be direct, and won't fade through the colors of your wheel.
Posted: Tue Oct 26, 2021 1:40 am
by EVOLVEINSTALL
Thanks for the work around.
Beta Issue?
if i change the mover colour in the selected timeline, the 2D Visualiser changes the colour, yet the timeline indicator square remains a white box.
I'm offline, just noticed that trying to look @ a full spectrum of 512 and trying to grasp what changing and not knowing the channels, to know what the DMX output is doing...quite a challenge.. Would be good if there was some kind of colour indication that channels are static or changing.
Posted: Tue Nov 02, 2021 7:57 am
by TomHat
Noted. Thanks for the feedback.
