Calender setings
The star of the STICK family.
Gerd
Calender setings
Post by Gerd »
Hello
I need help to run cue´s automaticly with the calender funktion
Hardware is Stick DE3 FW is Ver 1.11 ( 2017-06-01)
Software ESA Pro Vers 05.05.2017
The work araound like in the Manueal we dit it x times
Ceck with hardwaremaneger the stick has the right time and Date
in ESA
Drag Cues Into Calendar
Edit Cues To Set Time
Save Show
Write the Interface’s Memory
Close Program
Disconect PC
It has never work,
I can´t find my mistake
are there any options in the genral set up in hardware manager with enable or disable ?
Tanks a lot
pvb
Re: Calender setings
Post by pvb »
Did you assign the scene to the stick
Assign all scenes(Current page)
or
Assign all scenes (All pages)
That worked for me...
Hi Gerd,
Connect your Stick-DE3 to HardwareManager.
1) Check that Settings > T Time enable is ticked. (It is by default)
2) Check the Clock > the time is correct. Sometimes a DE3 won't hold time if the LIR2032 battery needs replacing.
A great way to test time triggers is to use HardwareManager.
- Go to Clock > RealTime Clock.
- Uncheck 'Synchronise to System'
- Manually enter a time 30 seconds in the future and press 'Set ->' button. The DE3 is now set to this time/date.
- Close HardwareManager to enter Standalone Mode.
- Wait 30 seconds with a stop watch. Does it trigger?
clock - sync.png (28.36 KiB) Viewed 9865 times
