I using ESA2 to program scenes with trigger and stored in STICK CU4.
However, the trigger is not work for CU4.
I tried to use hardware manager to check the port trigger and it is work.
The port signal under hardware manager is correct and change from red to green when I tried to trigger.
Please help and urgent.
Dry Contact is not function for STICK CU4
Moderators: simonB, nick, florent
Re: Dry Contact is not function for STICK CU4
Sorry, this there was a bug in an older firmware which prevented the ports triggers from triggering scenes on the Stick-CU4. This has now been fixed in firmware version 0.94 which is available in HardwareManager with ESA2 Beta (dated 30/01/2017) available on the downloads page.
https://www.nicolaudie.com/download.htm
1) Download and install ESA2 Beta.
2) Open HardwareManager and update your firmware to 0.94.
3) Create several scenes with Port Triggers. See information here:
https://www.nicolaudie.com/manuals/#/en ... e-settings
4) Write the show to your CU4 using the Standalone screen.
You will now find that your scenes trigger correctly with the ports.
