As the subject states I try to export scenes to Slesa UE7 from ESA PRO via micro SD card, not via wifi.
I have to send updated light shows to my clients who has a Slesa UE7 installed, but which is not connected to wifi.
I just can´t find any way to save the shows to the micro SD card, or any disc.
What to do? Or rather how to do it?
Best regards
Jan
How to export scenes to Slesa UE7 via micro SD card
Re: How to export scenes to Slesa UE7 via micro SD card
Hi Jan,
In the stand alone tab there is a option to write the show to your computer or SD card. Insert the SD card and press the button 'Write the show to computer', it will ask you where you want to save the show, select your SD card. You will then need to select what device you have, once you have done this the show will be written to the card and you can send it on to your client to insert into their device.
- Screen Shot 2015-08-13 at 11.02.51 (2).png (93.79 KiB) Viewed 9491 times
