Hi All,
Here some thinks i don't think are working as they should be:
Console:
+ Selecting next/previous console preset by the command does nothing on a tablet (easy remote).
(Link a button to: Live/New/Console/"Select next console preset") Its works on windows7 Pro but does nothing on the tablet (Android 4.0 and 4.1)
+ When loading "EasyCon big" as new console --> software crash
+ Load "Easy Remote Big" as new console, assign Midi Status/Command/Channel to it, set feedback True, move fader on tablet ---> software crash
+ Make new console in console builder, pre name a Wheel, text doesn't appear on tablet.
+ Affect Bpm works fine, but can only be controlled by a wheel, Wheel resolution to high to make little adjustments. should be nice to have a plus minus 1bpm button.
+ Make new page, "Showtec/ sunstrip active DMX" Batch delete all, Encountered an improper argument. but every button is gone, now make new button... again Encountered an improper argument.......
+ Not possible to fade Out a button
I'm programming a full 3 universe show now so if i run into something i let you know...
Greetings
Gert
Bugs Version 1 Juli
Bugs Version 1 Juli
Re: Bugs Version 1 Juli
Hi Gert
-where did you position the text in relation to the wheel?
-perhaps you had a console loaded and then removed before inserting the wheel? In this case, right click the component and re-add the text on the Console Setup tab
I'll see if we can add a +1/-1 to BPM in a future version
The selected preset can only be changed on the tablet by swiping.+ Selecting next/previous console preset by the command does nothing on a tablet (easy remote).
If you mean MIDIcon big, try the attached file+ When loading "EasyCon big" as new console --> software crash
I can't reproduce this. Do you have a MIDI controller connected?+ Load "Easy Remote Big" as new console, assign Midi Status/Command/Channel to it, set feedback True, move fader on tablet ---> software crash
This is working for me+ Make new console in console builder, pre name a Wheel, text doesn't appear on tablet.
Did you try to change the resolution?+ Affect Bpm works fine, but can only be controlled by a wheel, Wheel resolution to high to make little adjustments. should be nice to have a plus minus 1bpm button.
What do you mean by 'Batch delete all'?+ Make new page, "Showtec/ sunstrip active DMX" Batch delete all,
We'll check this out+ Not possible to fade Out a button
- MidiconBig.csl2.zip
- (6.72 KiB) Downloaded 641 times
