Controlling Color Mixing All with MIDI controller fader
Toka
Post by Toka »
I use Color Mixing All switch to control the overall color of animation. Then I set my switches to "subtract from current" prioirty and animate them in black and white.
It would be very handy if I could control the Color Mixing RGB values from controller, but I wasn't able to map it. Is it possible?
R G B values
R G B values
Color Mixing ALl.png (80.44 KiB) Viewed 7442 times
In order to control it I had to keep the color mixing editor window open and map the faders there. But even it that case, it works only if the editor window is in focus.
Thank you.
Re: Controlling Color Mixing All with MIDI controller fader
This should be possible. What exactly do you want to control? The RGB values of a lighting fixture with 3 faders of an EasyRemote/MIDI/DMX device?
