Midi controler Traktor Kontrol F1
laserrichi
Post by laserrichi »
i want to use this Controler. Now i want to make a Setup. The buttons have RGB LEDs inside.
How can i use this ?
Have anybody already use this Controler ?
Richard
Re: Midi controler Traktor Kontrol F1
Hi Richard
I've made this controller because I wanted to test some of the new features in the builder. Extract the attached Zip and copy the CSL2 file to the _common/_console directory, and the contents of the CCD and Background folders to the CCD and Background folders in the _common/_console directory.
I did some research on the controller and checked the manual, however there is no documentation on how they have implemented the MIDI potocol and how to control the color of the LED's. For now NI say this isn't possible by MIDI and you must set the controller pads to on/off mode. Once you have loaded your controller you will need to learn the MIDI commands, this can be done by clicking the small arrow in the top right and selecting 'Learn MIDI console preset'.
traktor f1.zip
Traktor Kontrol F1 console files
(104.27 KiB) Downloaded 745 times
