DMX input problem
LJKEKS
DMX input problem
Post by LJKEKS »
Hello! Faced with such a problem. The beta version of Sunlite suite 2 does not work dmx input. The controller signad goes, but in the program, nothing happens. Although the release of December 20, everything works fine.
Re: DMX input problem
-Have you checked the DMX interface settings in the software preferences->output window?
-Does the DMX input work on the test tab of tools.exe?
-Which firmware version are you using?
LJKEKS
Post by LJKEKS »
Yes, I checked through the utility. In the settings you tried to manually put the interface and automatically. Firmware 1.08. with the version of 20 December 2012 dmx in work. In the new version does not work.
...does it work?
LJKEKS
Post by LJKEKS »
yes through the utility input works. levels changed as needed.
hsteppke
Post by hsteppke »
Dont you have to asign the fader in the Console Editor to your Buttons first, befor anything does happen ?
For example going to the ConsoleEditor and right click (if i remember correctly) to one of the faders there and in that Dialog you can assing it to your Buttons/Channels etc etc
Are you trying to use the DMX input with the console or with the button editor?
Can you send a screenshot of the software preferences->output window?
LJKEKS
Post by LJKEKS »
I'm trying use the DMX input with the console. Yes, I can make a screenshot. The problem with the DMX input last betta not decided yet. It works only in the version of 20 December 2012 and previous versions. If this is how it will help here's PC Configuration: Intel Core 2 Duo E4600, Video: Nvidia GF8600GT 512MB, 2GB RAM, Win 7 32bit. I Interface Suite 2BC.
Hardware Settings
Hardware Settings
djeenl
Post by djeenl »
LJKEKS wrote:I'm trying use the DMX input with the console. Yes, I can make a screenshot. The problem with the DMX input last betta not decided yet. It works only in the version of 20 December 2012 and previous versions. If this is how it will help here's PC Configuration: Intel Core 2 Duo E4600, Video: Nvidia GF8600GT 512MB, 2GB RAM, Win 7 32bit. I Interface Suite 2BC.
Same problem with windows 8 i7.....
Kind reagards
Evert Hendriksen
E-3vents.nl
DJ, Productions, Stage
(Holland)
LJKEKS
Post by LJKEKS »
Here is a video of my problem. It is seen that the signal comes and input levels are changed in the test tool also in SL but fader console Sunlite not respond.
http://www.youtube.com/watch?v=oXPLICdB ... e=youtu.be
Sorry it's taken so long to get back to you, so DMX input seems to work in the input window and in the button editor but not in the console. We'll get it corrected in the next version
