where can I download the default program of the stick DE3?
While "playing" with programs, the stick has a rubbish-program now.
on 31/12 we have visitors, and I want to show them something... can I find the original (global) program somewhere:
1)red - 2)yellow - ... - 8)rainbow
default program
Re: default program
You can download the default show here:
http://www.nicolaudie.com/downloads/fil ... e3show.zip
The zip must be extracted and the folder should be dragged and dropped into the root of the SD card
Re: default program
simple as that.
works fine, now I can play and mess around - knowing I can always go back to default.
Thanks.
Thanks.
Re: default program
Still i found a little bug - i think...
in scene 8 - rainbow - when you manually override the speed in uptempo (over 100%) it works fine; but beneath 100% the speed does not adjust.
Re: default program
I've just checked this out and it works fine on my DE3. Try with the latest firmware
Re: default program
I am sure that both esa pro and the firmware is latest version as provided on:
http://www.nicolaudie.com/en/stick-de3.htm
But maybe I found the problem for this are a lot of other strange reported facts where allways is related to "the latest firmware".
first I deleted all previous downloads and previous extracted files related to "hardwaremanager".
I downloaded the .zip again and re-updated my DE3 today. The UI confirms I still have the latest version: 0.98
And than I started thinking... strange that months after release there is still a version 0.9...
the site mentions a firmware dated 7/12/12, but the published date of the firmware is compiled 24/10/12.
there are 6 weeks between these dates...
Are you sure the latest version of the firmware is zipped in the provided file?
http://www.dmxsoft.com/global/ftp/hardwaremanager.zip
I hope this is it, so a lot of my (and others -so i read) strange facts can be solved
Re: default program
This is the latest official firmware. Select beta from the top menu to load the latest beta firmware
