we experiencing some sort of noise with SUITE2-EC Economy Class,
the main issue is we having some China custom made led panel, and it so sensitive to noise since the fixture wasn't quiet fine made. Somehow, I found out there is some noise around some certain channel, which is around 433, and it happen on all the other universe, I have test it all, that have trigger the led panel flicker, we just found out that lately, at the beginning I though that is hardware issue on the led panel.
Please provide a situation for this, this is real real urgent, we have to fix it asap, otherwise we just have to avoid those channel now and duplicate other channel on that panel, a million thanks for your help!
found noise on certain dmx channel
Re: found noise on certain dmx channel
first of all try with the tools app which can be found in the software directory, click the test tab and move the faders to see if you have the same problem
if you have the same problem with the tools application, try clicking the DMX timings tab and write the enhanced compatibility timings to each universe (universe can be selected at the top)
