Upload firmware failed
teatralnik
Post by teatralnik »
Greetings
Trying to update firmware on siudi and it sends message "Upload firware failed"
teatralnik
Re: Upload firmware failed
Noticed that time and date settings are wrong. Trying to set them to correct values and thay are automatically rolled back to 1970 year.
you have an old versions of the tools. Download the latest Suite 2 and open with the version of the tools included with the software
teatralnik
Same problem. When I press "apply" hardware date and time resets to 4:00 1970 year.
Try setting the time using the time tab. It could be a problem with the battery. If your time triggers are still not working after setting the correct time with the time tab, I will arrange to have the unit swapped over.
you could also try replacing the battery, it is an LIR2032
