can't patch from 1.07 to 1.08
User based support for the SLESA-U6 - SL512BC - developer kit
Astey
Post by Astey »
hi,
im unable to update firmware from 1.07 to 1.08
i used 4 different computers and everytime it fails xp/w7. i hit patch firmware, the box is blinking after a while tools.exe returns with the message please patch to 1.08
its impossible to use suite2 anymore until its fixed
i use a siudi 8c
regards
Re: can't patch from 1.07 to 1.08
With some interfaces, it's not possible to upgrade the firmware from 1.07 to 1.08. To do this, you must start in 'bootloader mode'.
-power off your interface
-create a shortcut on p2-p3-p4-GND ports
-power on your interface
-start tools.exe
-update the firmware
-remove the shortcut
-start tools.exe
-update the firmware again
Here is a diagram showing the ports you must connect.
bootloader mode smaller.jpg (41.7 KiB) Viewed 11804 times
If you don't have the correct cables for this, a quick solution is to use a ball of foil. As long as the 2 pins on the right are not connected, your interface will successfully start in bootloader mode.
