19" adapter
raystream
19" adapter
Post by raystream »
hi
is there a 19" adapter out there?
i know there is one for the daslight DVC2 1024 Gold, but my interface uses a mini usb connector the daslight a normal sized one.
RayStream - Media
http://www.raystream.de
Re: 19" adapter
Hmmm not that I know of...does anybody else know of one?
hsteppke
Re: 19" adapter
Post by hsteppke »
HI,
there is this DAS light Rack Mount.
http://www.musik-produktiv.de/daslight- ... -gold.html
It looks like you have to remove the Housing of the Original Interface and then mount it into the 19" Box.
The XLR get attached to the Front and the Buttons (which i like) i guess will get connected via a similar connector like on my FC Interface i own.
Also for the USB i would assume the connect a simple cable to the Back and there (i found no picture) use a a Neutric USB Plug, i would use hot glue to attach the USB to the Interface card and the Neutric Plug so it cant disconnect accidentally.
The only Item i could not figure out is about the DMX Leds, there is one on the Front of the 19" Housing but how do they connect it to the Interface ? Maybe the DASlight has some Pin connectors.
To be honest it would be fantastic if there would be a 19" Housing. maybe you can consider offering one.
If there would be Pin Connectors for the DMX Leds, and the 3 Buttons and the 7-Digit Leds would be connected via a removable socket it would be pretty easy to have this as an option.
hsteppke
Re: 19" adapter
Post by hsteppke »
Found some more pics
http://www.ebay.de/itm/Daslight-19-Zoll ... 2ec01b07ed
looks like they just use the Interface and build it into ...
Re: 19" adapter
As we are primarily a software company it would not be cost effective for us to build one of these. This Daslight one is not actually manufactured by us and is a solution which has been built by a customer. There are LED outputs on our SIUDI8 and SIUDI7 boards for the 1st DMX universe and the USB connection activity. See attachment...
Documentation SIUDI7-SIUDI8.pdf
(149.99 KiB) Downloaded 1417 times
