Hello..
actually i tried to use "Strg Z"... because, i thought.. may be this will work like in some other programms.
Now i have a "Z" Sign in the Button of the Scene. if i press Strg Z... the color of the Z is changing.
Please could you tell me, what the Z is saying?
greez
Erich
What is the "z" saying in the Scene_Button?
Re: What is the "z" saying in the Scene_Button?
Hi Erich,
you just assign a keyboard trigger key to the button.
purple = latch
green = flash
You can delete the keyboard trigger when you:
- select the button
- hold down "Strg" ("Ctrl")
- press "Entf" ("Del")
or you can delete it in the button settings "Trigger".
Best Gernot
purple = latch
green = flash
- select the button
Best Gernot
- Contact:
okay...
thank you...
Erich
thank you...
Erich
