I'm having an issue running the 3d visualizer. The problem occurs whether I'm in demo mode or have the dongle plugged in.
I'm running Sunlite2 on one monitor and Magic 3d on a separate monitor. Everything opens fine, but when I minimize the visualizer window it always freezes the screen so when I re-open it it's just a blank white screen or has a frozen image of the minimized window.
I've tried shutting down the application and opening it back up, but it always sticks/freezes when minimized.
I'm running Windows 7.
Any assistance on this would be great as I can't do an offline programming right now without the visualizer.
Screen freeze with Magic 3D Easy View
Re: Screen freeze with Magic 3D Easy View
Update.
I've uninstalled the version of Sunlite that I downloaded from the website and installed from the disk that came with the usb dongle. The visualizer seems to work fine, but now I'm having an issue with the profile for an american dj scanner not loading. When I attempt to add a page for the fixture it just says "Could not load library".
Can anyone help me out?
- Contact:
Hello...
After doing this, i was able to load the Library. may be it will help you?
best regards
erich
I had the same situation. i opend the Library by using ScanLibraryEditor.... and then i saved the fixture as a *.ssl2 Library file (Use the "Save As" function, and select the *.ssl2 file format)"Could not load library".
best regards
erich
Has anyone else had problems with the frozen visualizer screen? It seems to happen every time I open another window (like a web browser) over top of the visualizer. When I try to go back all of the view ports are white and won't update. It seems like if I could refresh the screen it would fix it but there isn't an option to refresh.
Completely closing down Magic 3D and re-opening it fixes the issue until it happens again, but I'd rather not have to do this every time?
which versions work and which don't
I've had the same issues with the current release and the beta release. I have not tested this on older version.
press ctrl+alt and click the close cross. Which dates do you see in the dialog?
thanks
thanks
Sorry it took so long. Just got the chance to try this....Here is the info in the dialog box.simonB wrote:press ctrl+alt and click the close cross. Which dates do you see in the dialog?
thanks
Easy View
Nov 29 2011
2011.09.08
Hi, sorry but I cannot reproduce this bug. I will keep a look out for it. Let me know if you can find any pattern such as graphics card type/screen etc...
