Is there a way to make a fader for a master dimmer? Two in fact. One for everything and one for just the activated scenes and switches? I remember having something like this in S1 however in the version i had it didn't work properly.
Master Dimmer
- Contact:
Master Dimmer
Mark Green
Mark of the Wild
PO Box 1102
Talkeetna, Alaska
907-744-1633 (mobile)
907-562-6689 (office)
www.markofthewild.com
[email protected]
Mark of the Wild
PO Box 1102
Talkeetna, Alaska
[email protected]
Re: Master Dimmer
Hi Mark,
have you tried the "Native" Master Dimmer of Suite 2 ?
You have to check "Show general beam controls" in the "Software Preferences".
There is also a master dial for Iris and Zoom.
But you can create a "Dimmer switch" with Add/Sub settings to make a Masterdimmer, if you like.
If a scene or switch isn´t active it don´t need a master dimmer.
Can you explain more particularly ?
Best Gernot
I don´t get this part.and one for just the activated scenes and switches?
Best Gernot
- Contact:
Re: Master Dimmer
I tried it but only half of the lights active would dim....RichterMC wrote:have you tried the "Native" Master Dimmer of Suite 2 ?
anomaly?
I did not have time to copy the show file , I will do so tomorrow and send it to you.
Mark Green
Mark of the Wild
PO Box 1102
Talkeetna, Alaska
[email protected]
Mark of the Wild
PO Box 1102
Talkeetna, Alaska
[email protected]
Re: Master Dimmer
Have all your Fixtures a dedicated DMX dimmer channel ?I tried it but only half of the lights active would dim....
Some RGB Fixtures have only R G B Channels for Color mixing and you have to adjust the brightness with these aswell.
The Masterdimmer won´t work here.
OKI did not have time to copy the show file , I will do so tomorrow and send it to you.
Best Gernot
