Stick audio with movingheads and led
Erik
Post by Erik » Mon Nov 29, 2010 8:21 pm
Is it possible to disable the movement of a macro from the movinghead out of the audio trigger? So i can trig some led fixtures on the audio only.
Erik
Re: Stick audio with movingheads and led
Post by simonB » Wed Dec 01, 2010 8:48 am
Hi Erik
The audio triggering on the STICK is a basic live function. At the moment it can only be turned on and off. When turned on, all scenes and fixtures will be sound activated.
Erik
Post by Erik » Wed Dec 01, 2010 12:15 pm
Not at the moment! This means it will come in the future?
Erik
Post by simonB » Wed Dec 08, 2010 11:08 am
This feature has been around for several months. However it is only available on products with a serial of over 1500
Erik
Post by Erik » Wed Dec 08, 2010 7:31 pm
If i have a Stick with a serial higer then 1500, I can trig some Fixtures separately from each other.
And how can i enable/disable that? in the software or on the Stick itself?
Post by simonB » Fri Dec 10, 2010 5:39 pm
Hold Select+7
See the audio tutorial for more info
ljudkillen
Post by ljudkillen » Sun Jan 02, 2011 12:18 pm
I think what Erik meant was if there will be possible to trig some Fixtures with audio and some by timeline. At least I do wonder that. It would be great to be able to program audiotrig in ESA.
Post by simonB » Mon Jan 03, 2011 6:13 am
At the moment, the STICK can only be in either "Audio Trigger" mode or "Time Mode", all scenes and fixtures are in the same mode.
