Some bugs in Nov,3,2010
I have found some bugs in Beta Nov,3,2010.
1_
Go to "Controller"----->"Console"----->right click on any fader----->choose tab "edition" right click on "New" choose "Control editor channel fader"
In the pop up windows "index"-----> I can write any number here, but SUITE 2 ONLY REMEMBER NUMBER 1 no matter which one number I wrote.
2_
If I try to save my show without interface connected------->Suite 2 CRASHES.
Thanks a lot.
Jose A.
1_
2_
Thanks a lot.
Jose A.
Re: Some bugs in Nov,3,2010
Hi again,
Console does´t work fine.
An example:
I go to Master page---->create 2 new switches I choose "Reset other buttons when activatet" for the two switches.
I assign A fader on my midi console to activate switch "A" and the same fader for DIMMER.
I assign B fader on my midi console to activate switch "B" and the same fader for DIMMER.
I rise Up fader A----->switch "A" is activated.Then, I rise Up fader B---->switch "B" is activated and fader A in midi console rises down.
After some changes--fader A up---->fader B up ----and so on------->midi console does´t receive correct feedback(faders A and B could be Up)
Thanks a lot.
Jose A.
An example:
Thanks a lot.
Jose A.
There is also an other bug here, when you type in the numbers with the computer keyboard in the "Index" field the button triggers aren´t deactivated and
the lights go crazy. This has been fixed in many places of Suite2, but here it´s till there.
Can you tell me step by step, please.
Best Gernot
Yes, that´s true.Go to "Controller"----->"Console"----->right click on any fader----->choose tab "edition" right click on "New" choose "Control editor channel fader"
I test with XP and Windows 7 but I can´t reproduce this.If I try to save my show without interface connected------->Suite 2 CRASHES.
Best Gernot
I Use Windows 7x32 and Win 7x64 and get same results.
Load any show---->"open save show" select "save"----->then suite crashes.
Thanks for your observations.
Jose A.
Jose A.
O.K. I get it to crash once, but I can´t reproduce this every time.I Use Windows 7x32 and Win 7x64 and get same results.
Does it crash on your computer all the time ?
Best Gernot
Suite crashes Most of times I try to save my show without the interface connected.
Jose A.
Jose A.
Now I can see what you are talking about, I try to save my show 3 times today and it crashes every time.Suite crashes Most of times I try to save my show without the interface connected.
This is very annoying, once Suite 2 crashes so hard that all the fixture patches were gone.
I send a crash log to Dylan, I hope he can find and fix this soon.
Best Gernot
There seems to be a problem with the open/save dialog as these problems are re-occuring on xp/vista/7 on all functions such as importing a fixture background image, importing a show, importing an icon, opening a midi console inside the console builder, etc....
Dylan is away this week but he will take a look next week...
Regarding the index bugs, I've logged these
Yes, but it seem like Lennon616 is right, it only happens when no interface is connected.There seems to be a problem with the open/save dialog as these problems are re-occuring on xp/vista/7 on all functions such as importing a fixture background image, importing a show, importing an icon, opening a midi console inside the console builder, etc....
I saved my show very often last night with an DMX interface connected to my laptop and the software didn´t crash once while saving.
But I found an other bug, sometimes Suite 2 will freeze when moving fixtures on the fixtures window.
I didn´t found a way to reproduce this yet, but I happen three time last night.
Best Gernot
I´ve found some bugs in "favorites".
Select "favorites"----->create two new buttons------>change "Icon"------->try to save the show------>Suite Crashes.(Most of times)
Another one:
Select "favorites"----->create two new buttons --------->assingn any midi control to each button------>Push hardware buttons to check it works----->
1,2,1,2,1,2 etc------>Suite crashes.
Regards.
Jose A.
Another one:
Regards.
Jose A.
Best Gernot
With or without an Interface connected ?Select "favorites"----->create two new buttons------>change "Icon"------->try to save the show------>Suite Crashes.(Most of times)
Best Gernot
I did all test about "favorites" with interface CONNECTED.
Regards.
Jose A.
Regards.
Jose A.
I tested and make some modification about favorites.
Please check with the release I'll posted asap.
------- Dylan --------
