The console response is very slow.
I take 1/2 second to rise up a real fader, but software´s console takes almost 4 seconds to respond to this action.
If I assingn a real fader to activate a switch in Suite, and I rise up this fader, the switch goes on rapidly, but when I rise the same fader down.....The switch takes almost 4 seconds to go OFF.
In this way the overal performance of Suite is very slow.
I´ve checked the same hardware in SUITE 2006 and I have found only a little delay.
Can you solve this problem?.
Thanks a lot.
Jose A.
Console Very slow
Re: Console Very slow
I can't find a delay here, please send me your show.
Why are you activating a switch with a fader?
Why I use a fader yo activate a switch button? Well,If I have progammed some similar effects(Strobe1,Strobe2 etc) I asingn them to the same fader with differents trigger values because in this way I need ONLY ONE physical control for two or three switches.
Thank.
Jose A.
Thank.
Jose A.
Hi Simon,
Jose is right here.
The Midi console GUI can get very delayed and slow.
Try to move several faders from a midi hardware controller at the same time.
Sometimes the GUI even got stuck.
While talking about midi,
I really need Suite 2 to receive Note On/Off Midi messages properly.
We talked about this here on the forum some month back.
Best Gernot
Jose is right here.
Best Gernot
Hi Gernot
There was a bug in the midi console feedback which has now been fixed. Also, the windows driver is slow of the bcf2000, the driver from behringer is better.
Regarding the note on/off. Dylan says its not finished. It is on the todo list...
