Basic Newbie Questions
wagnerp@hss.edu
Post by wagnerp@hss.edu »
I am just getting started with the Easy Stand Alone and SLESA U5 interface and I need some basic help. I have read the manuals, visited the forums, and tinkered a lot. I can't get program to play correctly.
I can control all channels manually, and upload to the SLESA, so hardware and software work fine. It is my wetware that is having trouble!
I can't get scenes to trigger with the Stand Alone clock, and I can't get scene transitions to happen. Here's the application:
I need to control a marine fish tank light system - to start simple:
All dark from 20:00 to 06:00
At 06:00 fade up all channels to full power over 60 minutes
Full power until 20:00 then dim down to black over 60 minutes
Repeat cycle every day
Which clock triggers should I be using?
How does the "Loop" option figure into all of this?
Steps have a limited length of "wait time" but I want hours, not minutes.
Please help me.
Thank you.
Phil W.
Post by bruno.falip »
You must use the "Appointed time" trigger and select 6:00 for your fist scene and 20:00 for the second one.
Then, select 60 minutes fade for your scenes and there is nothing to do with wait time since there is only 1 step per scene.
wagnerp@hss.edu
What do I do with "Loop" and the "fade" checkbox?
There is only 1 step, so always loop option is fine and select the fade option.
wagnerp@hss.edu
:P Thanks! Will test out tonight. PJW
