Hi guys
I've got a problem when I'm runnig a cycle in a show. I programmed it with the GO function so I can proceed to the next scene using the page down button. But when I'm in another page (different from the page where the cycle is created in) the page down function doesn't work.
Is there some workaround to make this work?
Cycle problem
To use a single cycle utalising multiple pages:-
Select the page on which you want the cycle to exist.
Create a new cycle.
On the page-listings page Drag and drop any page button into the cycle listing in the order you want them to appear.
For each action, Select the time frame for the action.
HEY PRESTO
NOTE:
To initiate multiply page buttons at the same time, set the time frame to minimum.
Create a new cycle.
NOTE:
