It's no use typing it in becuase half the time the bands change speed, and the audio analysis can never be 100% accurate, so every 30 seconds or so, I have to re-open the audio analysis and re-tap the beat.
This is also tricky because, when I have the audio analysis window open, the main Sunlite window is de-selected so I can't tap the BPM with the space bar whilst clicking other buttons.
Has anybody else had similar problems? If so, would you find an integrated BPM counter usefull?? (Please say yes, then they may put one in the next major release!). Maybe a small panel at the top where you can assign a shortcut key to tap out the beat. It also means I don't have to open the audio analysis if I'm not using the microphone, therefore saving processing power
