Dead channel
Dead channel
Channel number 16 is not working, my buttons are supposed to be outputting at 35% on channels 1-16. Yet the output bar at the bottom of the screen says only 1-15 are outputting a signal. What could be the problem?
- SuperMaxi Forumor
Re: Dead channel
There might be something that is sending 0 to this channel.
Cordialement/Best regards
Bruno Falip
http://www.nicolaudie.com
http://www.lightingsoft.com
http://www.dmxsoft.com
Bruno Falip
Re: Dead channel
Nope, I made sure all the switches and scenes were off and sent a signal from the master page, still nothing
- SuperMaxi Forumor
Re: Dead channel
Can you try with the Easy Stand Alone software? What is your interface S/N?
Bruno Falip
Bruno Falip
Re: Dead channel
I don't have the stand alone, it's the yellow box. Where would I go about finding the s/n?
- SuperMaxi Forumor
Re: Dead channel
The S/N is located on a little label on the board.
Bruno Falip
Bruno Falip
Re: Dead channel
there are two labels, sl1024ec and 562179397 siudi 5c
- SuperMaxi Forumor
Re: Dead channel
You can use the Easy Stand Alone software even if your interface is not stand alone version, I just want you to check to see if the same problem happens.
Bruno Falip
Bruno Falip
Re: Dead channel
Nope it works fine on there, I will try to redo the page and see if that helps
Re: Dead channel
Now that I made a new page it works fine, thank you for your help
