Setting up IP address
The younger sibling of the DR1, the DR2 packs all the latest features form Nicolaudie into a smaller box!
DMXMASTER
Post by DMXMASTER »
Just looking for some info on setting up IP address and port numbers. I can connect to the DR2 Lt via the USB serial connection no problem. It seems easy to change to network connection, but I am not having any success here. Does the unit come with a factory set IP? What is the port number required? When I try to add a device manually it offers up a port # of 2431 .
I am also having similar issues trying to connect with the NA touchscreen. I'll post another question in the relevant forum.
Re: Setting up IP address
Our DMX controllers don't come with pre-set IP addresses, however you can access all network-related settings via the HardwareManager tool included in your ESA Pro 2 package.
Hope this helps.
