using Palletes in combination with circle move
soren
Post by soren »
How can i use a Pallette to store a position and the use this position as start point for movements. (circles + other . . . . .)
I would like to be able to change a few standard positions and then all my programs use theese positions and move relative to that position.
When i then come to a new job i only need to change a few positions for each fixture and then everthing is running.
Re: using Palletes in combination with circle move
It is not currently possible to use palettes inside the XY effect however it is on the todo list
soren
Post by soren »
Thanks for a quick reply.
Until now i used e:cue and there the feaure was available. I will look forward to a release with this included :-) it makes your light programs extreme flexible!!
We going to aim to have it done for April
soren
Post by soren »
Hi.
Is there a example anywhere showing how i use the pallets in combination with circle movements?
I expect it is implemented in the newest version :-)
drag and drop the xy effect
generate a circle or something
click a point
select your position palette from the list on the right
right click to change the startpoint
