I have some Alkalite TP81 that i want to use with 24CH (8 seperate RGB)
How can this be done. I have tried to edit the TP81 fixture, but this does not work in the visualizer.
I have also tried to add 8 generic RGB. Theese are shown as bars in the visualizer.
Is it possible to make a RGB bar with 8 seperate units in the visualizer?
Trackpod split in 8 seperate RGB
Re: Trackpod split in 8 seperate RGB
This will not work in the visualiser as it does not support multi-beam, but this won't affect the output from suite2, however it will appear as multi-beam in the suite2 group window as long as the beams have been assigned correctly in the fixture profile.
Is there anyone who have already made this fixture (TP81) as 8 sections? I can see that a lot of other fixtures already have different modes implemented.
Any news regarding Trackpod TP81 with 8 seperate fields?
we can create the profile for you. read the sticky in the scan library thread for instructions on requesting a profile
