x y buttons
- New Forumor
x y buttons
i got aproblem with x y buttons in my page of scanners i work whith 26 scanners and i can not see all the fixture button
Re: x y buttons
Hmm
-Are you using the latest ver? (30 dec)
-Which fixtures?
-You can't see the XY buttons at all, no scroll bar appears and they disappear off the side of the screen?
-Which fixtures?
- New Forumor
Re: x y buttons
work in the lattest version 30 dec the fixtures are fal hurricane 3408
- Dibujo.jpg (37.4 KiB) Viewed 4517 times
Re: x y buttons
what happen when you just resize (bigger) this window ?
Best Gernot
Best Gernot
Re: x y buttons
I didn't know you were using an external XY window list.
As Gernot said, make the dialog wider by dragging the bottom right corner.
I would never use this type of compression for this amount of fixtures, I would either use..
A. The external XY window icon compression
B. I would set up a new XY page layer and use either the icon compression or no compression at all
See the "Arranging Buttons" video tutorial (in the programming sub menu) for more info on compression and page layers.
http://www.nicolaudie.com/nicolaudietv/ ... suite2');"
