New layout sep 30 for new fixtures
I have some fixtures added in previous release ( sep 24 and earlier ). Now in rel sep 30 I add the same fixtures ( par ). And now I see that the color mixing button is actually a very large new tab in this fixture, while previous it was only a popup. Question now is how I can do the same for my older created setup withou deleting of course, otherwise I loose all my scense/switches.
Re: New layout sep 30 for new fixtures
This has something to do with the page "layout" settings, if you switch to default you get the old style color mixing external window.
I will test some more...
Best Gernot
Best Gernot
See the programming->arranging buttons tutorial at nicolaudietv.
We will be changing the XY grid layout so the buttons appear below the grid in the next release.
You can remove the buttons from the color mixing layer and add the old external compression window in the page settings if you need the extra screen space.
Hi Simon,
this is a great feature, thanks for letting us know.
When did you update the Video ? I haven´t seen the last part before.
Best Gernot
Best Gernot
Thanks for the explenation.
I saw interesting things like grouping the same effects under one button.
It will create a better overview.
Only a remark about this. I call my scenes something like chase RB ( which means red and blue) . So I know what it does if I click on that button. Now on the tv I saw that after grouping you only had 1, 2, 3, 4, ....
Is it possible to also see the original name you gave after grouping?
