hi, some ideas/improvements for midi:
for example new controllers like the akai apc40 or novation launchpad need some more information to display active buttons right.
perfect scenario:
- midifeedback is sent when controller button is pressed
- linked buttons of the controller to scene/macro have a background colors
-> there can be independent midifeedback values between 0&127 specified for each button status. for pressed and not pressed buttons. for example buttons, who control movingheads are red and for scanners are green, if they are pressed/active they turn into bright red and bright green.
- midi signal is sent when changing scenes with cursor without touching controller. works great already
regards
cedric
midi controller
midi controller
- novation-launchpad.jpg (47.09 KiB) Viewed 5237 times
Re: midi controller
generally i have to say: awesome work you guys!! with great ideas! really!
if you run the software a while and then you rearrange the midi/output (& input ports), more than once with hitting ok. the application freezes on windows xp.
cedric
cedric
Re: midi controller (Novation Launchpad)
anything of the above been implemented yet ?
eg the different Background color feedback would be fantastic ... yellow if a Scene is asinged, Red if its a switch and so on. aktivated and not aktivated ...
Also is there a way to share eg consol drawings ? and someone willing to do so ?
Regards
Holger
Regards
Holger
Re: midi controller
console drawing can be shared on these forums if anyone is willing to
if you check out the setup tab on the console, there is now a parameter "feedback when received control data" which relays the data back when received
it is not currently possible to send a different feedback message depending on the item changed, this is a big job to program and I think about 2 users will make use of it
Re: midi controller
Is someone have some news about this table midi for launchpad ?
