Button drag and drop
Schadow63
Post by Schadow63 »
I love being able to drag and drop a button to another scene or switch to add the parameters. It makes it easy to make changes to a scene. It would be nice if there was a way to drag and drop several buttons at once though.
Lets say I wanted to add movers to a scene on the master page. I add a pattern, a color, a gobo, rotate the gobo, add a prism and rotate. Now I have to drag and drop six buttons to the scene. If I want to do this to sixty scenes then I have to drag and drop 360 times.
If there was a feature that allowed to drag all buttons at once then that would only be 60 times.
Is there a way to do this or can that feature be added to a future update?
Thanks.
bruno.falip
Post by bruno.falip »
We will think about that for next versions.
johanspijker
Post by johanspijker »
Is this not a possibility ?
You make a new switch: "as you see now"
Then you drag and drop this new scene on the scene in the master page.
Schadow63
Post by Schadow63 »
I suppose I could create a switch and then delete it after the drag and drop, cutting 360 clicks down to 120 clicks. But a drag and drop all button would still be easier. In the mean time I will use that idea. Thanks.
