Easypro not reading extentions .sdp .sdv
Hi guys, Im trying to edit my current sceen set up that was done by someone else, and cant seem to get easypro to read the extensions. Is anyone familiar with these extensions .sdp .sdv? Id prefere no to have to rewrite every scene, any information is appreciated. Cheers
Re: Easypro not reading extentions .sdp .sdv
Hi Benejamin,
.sdp .sdv are the raw showfiles which are not readable by ESA Pro. You will need the original .arc file used to write the show or .dlm if it was written using ESA2. Earlier versions of our software did not automatically save the showfile to the SD card. So, success depends on which version was used to write the original show. If a show file is not on the SD card and you do not have access to the original, you will need to recreate the show from scratch.
