Combine to masterpage?
Posted: Tue Apr 04, 2006 4:24 pm
by flipje100
ive discovered e problem.
I have two pages. one with scenes and switches for color changers ( call it CC-page)
and one with scenes and switches to control madscans ( scan-page)
now I select a scene in de CC-page for some colors. then i select a switch whitch give a moving light. I made it with some easy-time programming. the switch is in ADD-mode ( it will add the differents, dmx value, between two colors)
on the scan-page i select also a scene for some movment ( easytime)of the scans.
Now i went to combine these two pages to the master page.
al went well, only the easytime info of the ADD-switch of the color-page is missing. The scans working fine and moving. but the colorchangers only gives the switch.
maby i want to much? and can't I combine two easytime scenes.
can someone explane the problem
thankx
Posted: Wed Apr 05, 2006 7:41 am
by Guest
Ok, found the problem. It comes from the "Add" function. We will fix it asap.
Posted: Wed Apr 05, 2006 7:16 pm
by flipje100
oke i'll wait for the update
succes
