How many lights can SL512EC run without a booster ?
Posted: Tue Feb 14, 2006 4:13 pm
by newtodmx
How any lights can sunlite run without a booster. Lets say i have 20 fixtures totally spread evenly over a 100 meter dmx line daisy chained. Each fixture has 10 channels. With a dmx terminator at the end of the line. Will the signal carry ?
Posted: Wed Feb 15, 2006 2:13 pm
by Guest
It depends on the cable, on the fixtures...this is difficult to say that. You should test and the use of a bosster is better.
Posted: Wed Feb 15, 2006 4:35 pm
by newtodmx
You mean there is not even an approximate safe limit. OK will this interface work over 2 meters of wire for about 5 fixtures ?
Posted: Wed Feb 15, 2006 6:15 pm
by roberto
I always recomend a DMX splitter/Booster at the output of my Sunlite Interface. It splits, amplifies, but the best is that because it is optoisolated, it will protect the Interface against voltages, ground loops, etc.
DMX 512 is RS485 serial al 250 Kbaud, as such any installation must meet the requirements of EIA485. In particular use of suitable good quality cable is important (Mic cable is NOT suitable) suitable cables include:
Belden 9841
Belden 9842
Alpha 5274
Amongst others.
The EIA485 standard supports a maximum of 32 devices on a line, if more are needed, a repeater should be used to add 31 devices more. The repeater is considered a device.
Each line must be terminated.
The total lenght of the cable per line in a repeater is 300 meters with cable 24 AWG or 500 meters with cable 22 AWG.
Posted: Wed Feb 15, 2006 6:18 pm
by roberto
In theory the Sunlite output will run 32 devices with a 24 awg cable of 300 meters lenght in total.
But I always recommend the use of a Splitter right at the output of my Sunlite. Then I have the option of 32 devices 300 meters long on every output of the splitter.
Posted: Thu Feb 16, 2006 8:11 am
by newtodmx
How much will a optoisolator splitter like what your mentioning cost ? And it splits the main signal into how many outputs ?
Posted: Thu Feb 16, 2006 4:04 pm
by roberto
There are optoisolators of 2, 4, or 8 dmx outputs , it depends on your need.
A two DMX output should cost around 150 dlls, depending on the manufacturer.
Posted: Thu Feb 16, 2006 6:42 pm
by newtodmx
is there a non optiisolator type also which sells cheaper or something ? and all splitters will also boost the signal ?
BUT FINALLY, if im within 100 meters of dmx cable (not mic cable, but dont know the technicals of the cable) with about 20 fixtures on the line. The i shouldnt need a splitter ? IM USING SL512EC.
Posted: Thu Feb 16, 2006 8:59 pm
by roberto
All good splitters, they isolate, amplifies and splits the DMX signal.
Your Sunlite will easy handle the 100 mts cable, and the 20 fixtures.
Try to use cable 2 wires twisted pair with screen.
To use the splitter is to go safe.
Posted: Fri Feb 17, 2006 5:26 pm
by newtodmx
How does one identify its a twisted wire cable 2 with screen ?
DMX cable
Posted: Mon Feb 20, 2006 5:20 pm
by hschaerer
You can use Category 5 shielded LAN (network) cable. It works well and is easily available and quite cheap.
