Moderators: simonB , dylan , RichterMC , florent
Masahiro Noda
Post
by Masahiro Noda » Mon Jan 02, 2006 12:26 pm
New magic 3D 2006 is very good software.
I just arranged fixture and all objects.
But it don't received DMX.
So fixture not beam out.
I am using 1 DMX input.
I think almost setting is OK.
What mistakes that?
Guest
Post
by Guest » Mon Jan 02, 2006 3:10 pm
Hi there,
First of all, thank you for your support. Then regarding your problem please check that the universes are correctly patched with the "Universes patch" window. You must select the DMX interface for the universe 1. Then you can check the DMX signal with the "DMX level" window.
Masahiro Noda
Post
by Masahiro Noda » Mon Jan 02, 2006 3:23 pm
Thank you reply.
DMX universe 1 to interface.
And select DMX universe 1.
It's OK.
DMX level is not move.
DMX input interface is OK.
Because, it is received DMX on sunlite 2004.
Guest
Post
by Guest » Mon Jan 02, 2006 5:19 pm
There was a little problem, please donwlaod the new file.
Masahiro Noda
Post
by Masahiro Noda » Tue Jan 03, 2006 11:08 am
problem was solved.
Thank you
