I currently have 2 daslight controllers which i have been using a love. However i wanted somthing more powerful so have purchased a sunlight desk however am having real difficulties re creating how my daslight desks work.
Firstly, i want to create an auto colour change / gobo program that changes the colour off all the lights every 60 seconds, ie so they are all the same colour of a 2 colour combination i have selected.
Secondly, i would like to create a button that blacks out all fixtures or turns them all on.
Thirdly, is there a button hi aracky like daslight has where say i press a button which is a strobe but it all blacks out all lights it automatically deselects the other button that are already selected.
Fourthly, i would like to be able to create a shutter chase program that opens and shuts the shutters on differant lights and pages to the beat of the music.
Any help would be much appreciate, i can post a link to my daslight setup if that would help you understand what i am trying to do.
Thanks,
daslight to sunlight conversion problems
i've never seen daslight so i'm not sure if i understand your questions exactly. But here are my suggestions:
1)
You could create a new, empty switch:
On the easy step rack, link the color-channels to the easy-step function without fade. Then adjust the 1st color/gobo of the fixtures (for more fixtures you could also use the copy-function here). Now insert a new step and adjust the 2nd color/gobo.
For each step you can set the wait-time to get the 60 seconds delay.
2)
If you create a page with the wizard, there is a 'Init'-Scene which sets all values to 0.
If you don't want all values to be reset you could create a switch where you set the appropriate channels to 0.
3)
By default the switches are created with 'automatically release in case of double-clicking another'. That means if you double-click another switch or scene all other switches are released.
4)
For this you can use the 'sound to light' rack within a scene or switch. Here you have access to different signals like bpm. Link the signals to the channels you want to control by music.
Hope this helps
1)
2)
3)
4)
Hope this helps
