I can't get our Fazer X310 working on Sunlight 04.
It's not a hardware problem, because I got 2 of these machines and they both have the same problem.
DMX signal works fine on a Lightprocessor Q12 controller, but on the SL04 I can't control the hazer.
Does anyone has experience with this?
Antari X Fazer 310
- Junior Forumor
Hi there!
I also have an X-310 with the X20II DMX interface, but I have got it working OK with Sunlite 2004.
It uses two channels, but they are the reverse of what the manual says.
The first channel controls the fan speed, the second channel controls the haze volume.
If you like, I can send you the simple "fixture" definition file I created. Should I use the e-mail address on your website?
Regards, Vince
Regards, Vince
