Contact Ports issue
owenkoo
Contact Ports issue
Post by owenkoo »
I have Two dina-dr1 and Two dina-dr2 to control tracing led strip in Four rooms separately; 3rd party control from AV system by using dry contact port to dina-dr1/dr2.
I try the contact port signal with maintained and pulse (1 sec) option. It Indicate “maintained” contact port signal to cause the controller hang up. However, the pulse contact signal do not.
Could you advise the instruction of using contact port?
I use ESA PRO 2 software for programming, maintained use “Held” function, while Pulse signal use “Press” function in program.
BR,
Owen
Re: Contact Ports issue
We were recently made aware of an issue of this kind with our DR1's dry contact port triggers. The issue has been fixed, and the fix will be released in next version, coming before the end of the month. If you need further support, please feel free to contact our support team directly here : https://store.nicolaudie.com/en/support
