ESAPRO2 - KE2 - Port Triggers
Touch sensitive, intelligent lighting controller.
Programmed via ESAPRO2, in stand alone mode.
2 ports - HWM confirms both are perfect in terms of responses, no ghost signals. Perfect.
Page A - 1 Playing
Port 1 Triggers Page C1 - Fail
Port 2 Triggers Page C2 - Works
Port 1 re-trigger - Works
Port 2 Re-Trigger - Works
Port 1 re-trigger - works
Page A - 2 Playing
Port 1 Trigger C1 - Fail
etc etc
Also, in Page A, When the Port is triggered - the KE2 jumps from Page A to Page C. Why does the Port have respond with feedback when its on its own separate zone? Would prefer the ports not to respond in this manner - would be great to have an option regarding this.
Re: ESAPRO2 - KE2 - Port Triggers
I'm afraid I'm going to ned more details here. Maybe a project file ? I'm not sure what you're trying to achieve and what's "Failing" exactly.
Thank you Tophat.
Nick in UK was able to deal with this issue, i believe it was a bug which got fixed.
The only 'thing' that remains, which nick said would not be possible.
KE2
If i was playing a scene on Page B. Pressed my external DC trigger, which is a scene on Page C. It will not trigger in the background, so when DC is triggered, if i was on Page B it would now be on page C. Would beamazing if somehow we had an option that the scene would play but the controller feedback would remain as is.
