ESAPRO2 - RGB but links to Pan & Tilt
Posted: Wed May 04, 2022 8:00 pm
by EVOLVEINSTALL
RGB Pixels - ESAPro 2 Seems to think it has Pan and Tilt Values
Re: ESAPRO2 - RGB but links to Pan & Tilt
Posted: Tue Jul 05, 2022 8:18 am
by TomHat
What happens with this editor is that it goes into "global" mode whenever you try to create effects on more than one TYPE of fixture. It's also always in this mode when you try to set values on the Master timeline.
In "global" mode, it will always allow you to edit COLOR, DIMMER and PAN/TILT values.
I hope this helps understand the way EP2 works. If not, I'm at your disposal for any further questions.
Posted: Wed Jul 13, 2022 12:49 am
by EVOLVEINSTALL
Understand.
It could be mistaken as confusing.
Noticed, that on a 'only' a RGB project - Pan&Tilt did not show up in the timeline menu
However on a Single Channel & RGB Project - Pan&Tilt did show up in the timeline menu (nothing moving)
Posted: Thu Jul 21, 2022 1:14 pm
by TomHat
Interesting... I'll look into that.
Thank you again for your feedback.
