I need to connect more then two universes in stand alone mode. How could I possibly do that?
Multiple universes
Re: Multiple universes
The SLESA-U9 will only output 256 channels on a single universe.
For 2 universes in standalone mode you will need a SLESA-UE7.
Thanks!
About "STICK's" or "SLESA".
It is possible to connect several devices in Master-slave mode to increase the number of universes?
This is possible with the SLESA-UE7.
See page 2 of the SIUDI-7B datasheet:
https://storage.googleapis.com/nicolaud ... eet_en.pdf
And the section called 'Synchronization of USB-Ethernet controllers' on ESA Pro Network Control.
https://www.nicolaudie.com/manuals/#/en ... rk-control
I would strongly recommend buying a dedicated wireless access point just for this purpose.
It is not possible with any STICK controllers. You can sychronise STICK-KE1 / KE2 and DE3 areas so that they play the same scenes in different rooms, for example. But you cannot output more than 2 universes in standalone mode on a STICK controller.
