copy scene between areas -
Posted: Mon Sep 04, 2017 2:20 pm
I'm buiding a standalone show to enlighten statues, using SLESA-UE7 and ESA Pro. I have two statues for one hardware interface, so I've been playing with areas. In the first version both statues will show the same scene, but this might change in the future. Plus I'd like to be able to tweak each scene for each statue because the light setup and statues are not exactly the same. The fixtures are exactly the same for both setups
Is there any way to quickly copy a scene between areas ? I'd like to work on one statue and when I found all my settings, copy the exact same show on the other area. For what I've seen it seems like I must make all the scenes by hand.
Thank you
Thank you
