Sunlite 2015, feb ( waiting for new non beta version )
hardware EC
console akai lpd8, four page midi console.
When Im saving the show where I reference the midi controller is the midi console setup also saved ?
Current show setup I have one tab for each page the akai have ( p1 , p2. p3 , p4 )
Tia
Steen
How do I backup midi console setup ?
Re: How do I backup midi console setup ?
Hi Tia,
Yes, the midi console setup should also be saved in the showfile. Are you finding this is not happening? Are any console settings saving at all?
I recommend you try the latest beta version, as this contains many bug fixes.
Hi Nick
Thanks for the reply.
No I havent recently checked whether the show backup was actually working, I have done it a long time a go.
I remember that when Im importing a show Im asked whether I want to use the "console inside the show backup or the console that allready in the sunlite installation" and from your answer I believe that I allways shall use the midi console settings from the show backup.
regarding the use of beta software :
I think you could consider calling your patched versions for something else then "beta".
I might be wrong but usually software is named "beta" because this version isnt for production use.
An examble of this use of the word "beta" is this : https://downloads.mariadb.org/mariadb/+releases/
I think that you are stating that your last public release ( 27/01/2017 ) is for production use.
Kind regards
Steen
BTW ( By The Way ) : TIA = ( Thanks In Advance ) :-)
Kind regards
Steen
