Esa Pro - Patch Displaying
ibanezc
Post by ibanezc »
Hello, i've just install ESA PRO (v. 16/08/2016) on my Microsoft Surface Pro 4.
My desktop is in 2736x1824 resolution
When i try to patch some fixture, i can't see all the tab and buttons to configure.
Imagedes photos
The resolution changing doesn't resolve this issue.
Do you have an idea to correctly displaying the software ?
darklightseattle
Re: Esa Pro - Patch Displaying
Post by darklightseattle »
I am having the same problem with my Lenovo Yoga laptop (windows 10). Trying to change the resolution is not effective. I realize this is not a helpful reply but I am hoping for a solution as well.
Thank you for your question. This problem is caused by text scaling on high resolution screens in Windows which unfortunately is not supported by ESA Pro. You'll typically see this on laptops. To fix this problem you need to reduce the amount of scaling used to 100% or 125%.
Please see the attached image as a guide.
https://www.thurrott.com/windows/window ... ay-scaling
If you find this makes the text too small to read you can also reduce your display resolution under 'Advanced Display Settings' in Windows.
text scaling.jpg (52.99 KiB) Viewed 10249 times
