I have two Stick DE3's.
Made a show in ESA PRO. Saving to device both via network or USB works fine.
Shows are actually saved to SD card and can be seen when i insert SD to PC.
When try to use DE3, it shows Empty SD Card.
In the show i have 16 scenes. Sometimes when i boot the controller it shows name of Scene 4, then whenever i press anything it goes Scene OFF and does
react to anything else. Reboot, the same happens.
Any shows that i save to SD are not readable by ESA PRO. It says no shows found, though they are actually on the SD itself.
Also tried "save to computer" and save to SD inserted in the PC, then putting it back to controller.
Nothing helps.
Tried 3 different SD cards, same happens. Firmware is 1.10 and cannot downgrade it, when the firmware update progress comes to the end at 99% it says device disconnected and stops.
5 days already and no success.
2 Devices don't save shows, show empty sd card.
Re: 2 Devices don't save shows, show empty sd card.
Kogan7,
Did you find a solution for the issue? Think i'm suffering the same, won't write the file to the DE3 but when saved via PC, it works.
Cheers,
Rob
Cheers,
Rob
